Folks - As some of you may recall, more than a year ago I began a series of Mallosi full-power upgrades on a stock 60th Anniversary editon LX-125 with the good owners and mechanics at Planete Scooter here in Paris. What started out as a desire to simply increase the pick-up on a standard modern Vespa turned into a major experiment born of my own curiosity of the scooter we all enjoy. And I believe you might find the results interesting and of value.
There's absolutely no doubt that increasing the size of the cylinder, changing the gears, shocks and adding all other applicable Mallosi modifications greatly adds to the power and enjoyment of riding a Vespa. Indeed, I'm not the only one on the forum who has expressed that sentiment.
But be advised that the upgrade comes with a cascade of mechanical and safety issues that need to be considered - and that these issues result from how Piaggio manufactures its Vespas and the so-called performance mufflers available on the market.
First and foremost, what I've discovered is based on riding the Vespa in an urban environment, on streets rough, smooth and cobbled. Highway driving amounted to four 100-mile round trips on motorways leading into and out of Paris. I use my Vespa as a commuter vehicle, to take the kids to and from school and to drive to work. One weekend jaunt a month with my wife.
The Conclusions
The speed and increased finesse that comes from a Mallosi upgrade must be weighed against the poor stopping power that comes from Vespa's decision to continue using brake pads on the rear wheel. The poor rear braking power is evident under all conditions and particularly under wet conditions. There is much danger in this. The problem was most noticeable and chilling on the highway. How often you tighten the rear brakes matters nothing. I doubt that Piaggio will ever address this issue; still, the company would be wise to install rear disk brakes. There's no way of getting around this worrisome fact.
I've installed and tested all available performance mufflers, which include PM Tuning Pipe, Scorpion stainless steel, Scorpion titanium, Leo Vincent and the Sito Plus.
Again, under the conditions that I drive in, the one-and-only can to go with is the Sito Plus and here's why. The Leo Vincent, PM Tuning and two Scorpion cans are easily and readily damaged in an urban environment. The Scorpion pipes, in particular, require constant adjustment and are frequently knocked loose. Although you can't argue about the fine sound and good looks of the Vincent, PM and Scorpion models, the power-hassle equation just isn't worth it.
The Sito Plus is by far the easiest to fit and maintain - and I discovered only a marginal difference in ooomph and mileage with Sito Plus. Where as the Sito Plus has gone for some 3,000 miles with no problems, the other pipes had to be refitted or repaired within the first 800 or so miles after installation. And, yes, each pipe was properly installed and by experts mechanics associated with professional and amateur motorcycle racing teams.
In the end, I figure how each of us customizes our own Vespa is a matter of taste and where we drive. At the same time, I do believe, or at least claim to believe, it's well worth considering what I discovered after a year spent experimenting with all the available upgrades. Happy trails to all.
