Martinvh wrote:
Kristof,
Do you know what type the fitment here in Europe is?
They are talking about a universal 1157 fitment, but I don't think that's what our indicator bulbs are.
I would like to order a set of these V-Leds (and maybe you do to).
In theory, for your European spec LX, all you will need is:
1. 2x Universal 1157 Socket. You probably can find them at your local auto supply store. You may also need to probably have to solder a 3rd wire for the ground if your socket does not have one. The current bulb in there is a type 57 in the US and V-LED does not sell white/amber LEDS for that type.
http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=BOR&MfrPartNumber=PT17&CategoryCode=4075B
2. V-LED white/amber 1157 bulbs
3. Roll of 14 gauge of wire
4. Solder gun and shrink looms for wires. You can use black tape as a substitute.
5. Couple of wire taps
6. 1 terminal ring for grounding
7. Multimeter or test light
Steps:
1. Tap into your running lights or parking lights coming from your main headlight housing (the real little bulb). I think the wire is Yellow/Back. Confirm this with your multimeter. Make sure it's the positive(+) wire.
2. Run that wire near your horn. Give plenty of slack when cutting the wire.
3. Wire up the new sockets.
NOTE: I am kind of guessing the wire colors for your EURO scoot. I'm just going off the US workshop manual. Please verify the + Positive with a testing tool.
