Faco rear bar and coolant leak
Post Reply    Forum -> General Discussion 12Next
2006 Midnight Blue GT200
Sun Oct 08, 2006 10:04 pm
I'll first admit I probably contributed to this problem...
I installed the Faco rear bars, nice product.
After installation, I pulled the bars back from the scooter because they were almost touching the paint and I figured vibration just might complete contact.
What I didn't realize is the Faco bracket made contact with the coolant hose as shown in the pic. My fix was to cut off the damaged hose, which had enough excess to to reconnect. This also changed the routing path and improved the clearance between the hose and bracket.
If you've installed these, you might want to check the clearance...
__________________________
Jim
Back to top
Silver Bullet
Sun Oct 08, 2006 10:13 pm
I did that when I put my Piaggio bars on. Tore the hose right off the nipple. Dumped all my coolant. Fortunately, I saw it and shut it down before overheating it.
Ride Safe,
Paul
If neccessity is the mother of invention, assumption is the mother of all fuck ups.
Back to top
GTL200
Mon Oct 09, 2006 9:23 am
I just replaced the coolant hose on my GT because of this. My crashbars also cracked the plastic cooling cover on the front part of the transmission case. Good new though, Faco have released new crashbar brackets that stick out a little further! Hopefully this should provide proper clearance (I haven't installed them yet... the front right bracket was missing from the box!) I'll let you know as soon as I get them on if this solves the problem.
Back to top
05' ET4 190, 74' sleeper super 190, T5 MK1 (busted), even less small frame's(down to 2), 3 Yamaha Zuma's (race team)
Mon Oct 09, 2006 11:34 am
yeah ive installed them on a gts before and the bracket was just eating away at the rad. hose... had to take them off and get the new bracket which wasnt even out at the time(i think they come with the new one now)
the new bracket works it pushes them out just far enough, but if for any reason they rubbed on the line... change dont fix you coolant line... a coolant line is way easyer and less expensive than replacing a blown head gasket or cracked cylinder....
if you need help doing so PM me....
thanks
FACE
Back to top
GTS 250ie
Mon Nov 13, 2006 7:21 pm
I have the "new" bracket. Same problem. I'm considering switching to the Piaggio bars, if the bracket for those is any better. Any tips?
Back to top
GTS 250ie
Tue Nov 14, 2006 1:13 am
With careful fitting and use of a couple of extra washers you can fit these without being too near the pipe. There are some articles about this in the Tech section with photographs too about how to modify the air filter cover.
It does work, you just have to be careful and also check the fitting after your bike has been in for a service just in case.
Charles.
Back to top
GT200 (girlfriend's), RD400, RZ350, Duke II, 1954 Allstate 125
Tue Feb 06, 2007 12:06 pm
Even with the updated brackets and proper use of spacing washers, the right bar will contact the coolant return hose in the event that anything hits it. My girl's GT200 fell over at a standstill. The damage looked to be minimal. I pulled the crashbar away from the hose, but it started leaking as soon as the scooter was warmed up and the coolant pressure increased. Luckily I noticed the coolant leak or the motor might have gone.
I think this is a pretty serious defect with these Faco bars. What good is protecting the cowl if you can't even ride the bike after a minor incident. If you are buying crash ars for a GT/GTS, I would strongly advise against Faco.
For reference, the damaged hose in my case is the lower hose:
part 577205, HOSE (ENGINE RETURN), $24.00
Unfortunately, my SF vespa dealer (Vespa SF) won't allow me to order the part unless I tow the scooter in so they can see it. They have a 1 1/2 month wait also!
I have to order it elsewhere. This is a Vespa, not a Ferrari. I am disappointed that they discourage do-it-yourself mechanics.
Back to top
GTS250 SOLD
Tue Feb 06, 2007 3:07 pm
I have the Piaggio Vespa Chrome Set on my GTS and they are sturdy and don't require any drilling or cutting to install them. They come together under the floor in the front and clamp witth several scews to the frame underneath the floor.
Bronwyn
VCOA #2819
Back to top
2010 Dragon Red GTS 300 Super, 2006 Smokey Grey GT 200
Tue Feb 06, 2007 3:50 pm
These are the rear crash bars I would get if I get them. My partner's GT has the Piaggio one's like that and the fit is great.
Benny
Diavolo Fortunato
First Red GTS 300 Super in Canada
Back to top
GTS250 GTS300
Tue Feb 06, 2007 4:14 pm
They're okay, but honestly I don't think they do a very good job attaching to the frame. The fastening mechanism is a couple of pinch-bolts, and these will pop right off in a collision or tip-over, and allow the crash bars to bang into the cowl. I saw the aftermath of an LX150 that had gone down with the same kind of crash bars, and the pinch bolts just popped right off.
Some front fender crash bars also attach with pinch-bolts, and these have been known to fall off with sometimes hazardous consequences.
Back to top
Tue Feb 06, 2007 4:34 pm
Where did you buy those?
Back to top
07 GTS250ie VCOA#2794
Tue Feb 06, 2007 5:27 pm
I think she got them from the dealer when she had her scoot shipped to Alaska.
David has the whole chrome set on his Vespa Riverside site ... .
http://www.atonofvespas.com/eshopprod_cat_2642-21526-21527_product_305049.GTGTS_Full_Chrome_Kit.htm
Back to top
Tue Feb 06, 2007 5:28 pm
Jess ... you are saying the pinchbolts under the floorboard popped off?
They also attach up under the seat.
Back to top
GTS250 Black!!!
Tue Feb 06, 2007 5:57 pm
I checked the clearance on my 250 and it seems to be ok.. "I hope!"
"Those who trumpet their sufferings are usually most deserving of agony"
http://www.myspace.com/hulkingwarmachine3
Back to top
GTS250 SOLD
Wed Feb 07, 2007 5:35 am
I got them from Vespa Seattle. That's where I got my GTS.
Bronwyn
VCOA #2819
Back to top
Wed Feb 07, 2007 7:20 am
I just got my Piaggio rear bars in the mail this week, (Thanks, Max) and I was impressed with the quality of the chrome, nice stuff. I referred back to the installation procedures in the tech section and it appears I have more hardware than is represented in the tutorial.
The top two pieces are the front mounts, the bottom pieces are the rear mounts and the two pieces on the side probably attach to the front or maybe they are designed for another scooter, who knows. The instructions that came with it are just a tad bit ambiguous. Is this the new hardware?
I'll let you know how it goes as soon as I install them. Hopefully, this week. The garage is heated but it has a hard time keeping up with near zero temps.
Back to top
Wed Feb 07, 2007 7:36 am
what thickness is themetal for that hardware?.
im making my own crashbars and im looking for a tried and tested method to attatch them to the scooter.
Vespa Gts 250ie. bitubo front shock, stiff rear springs, matt black rims and tranny cover, 1 off seat cover, aftermarket mirrors, original short screen, polini variator with 14.7g rollers, PM-Tuning pipe, stebel nautilus horn, EBC brake pads, floor mat, heated grips, handlebar to frame lock, chrome skull numberplate bolt, sticker's, black jettin visor, brass hooks for fuel can, 140 rear tyre, anti theft valve caps, datatag, NGK cr9eix plug, bottle holder, tinted indicator lenses.
Back to top
Wed Feb 07, 2007 8:10 am
Suit, the thickness of the hardware is 5/32's of an inch, or 3.96mm.
Back to top
GTS250 GTS300
Wed Feb 07, 2007 8:57 am
Yep. Or, rather, the pinchbolts lost their grip on the flange they were attached to.
Back to top
Wed Feb 07, 2007 9:21 am
cheers
Back to top
Sponsor
For Sale: 2001 Black/Tan ET4 with 700 original miles
Wed Feb 07, 2007 9:32 am
The Piaggio bars come with a zip tie to hold the hose back. That was their solution.
Max
Motorsport Scooters
info@scooterwest.com
www.scooterwest.com
619-280-1718
Tue-Sat 10am-6pm Pacific Standard Time
#1 source for all things Vespa!
Back to top
gt200
Wed Feb 07, 2007 10:19 am
Yeah that's pretty much what I did also. And will add a some sort of pipe cover for extra protection.
x
The Thread Killa & Dragon slayer (scooter style) RBSC#040
Back to top
Mon Feb 12, 2007 1:30 pm
I went to replace the hose this weekend and found out that I could get by with cutting off about 1/2" of the end of the damaged hose. The hole caused by the crashbar bracket is then positioned over the inlet pipe and can't leak. Certainly a preferable fix than stripping down the bike to replace the hose.
Back to top
Mon Mar 26, 2007 7:06 pm
ug!
i JUST found this thread.
i just had the same problem happen to me on the way home.
dang it!!!!
Back to top
Current: 2004 GT 200 & 1976 150 Sprint V Previous: VS5 GS 150, 1974 Rally 200
Tue Mar 27, 2007 3:03 pm
ok carnales, you convinced me to take mine off.
After reading the 2 negative threads I decided to look at my new coolant hose (provided by motorsports and installed at sfmoto) and low and behold it had some new wear. Then I as I mentioned above I removed the bars from the bike. Had I known of the problem last year I would have re-allocated the money to a chrome wheel from jettin'. Ah to live and learn.
VCOA #2759
Old Bastard Scooter Club #3641
"There is no Modern, there is no Vintage, There is just VESPA!"
"Hasta La Vespa Siempre!"
Back to top
Tue Mar 27, 2007 3:15 pm
anyone have a pic of the "new" brackets?
mine may be new - the part of the bracket right up against the hose has a countersink hole and tapered head screw - so there's no screw head poking out inside the bike. yet the rear attachment has just the screw hole - no countersink.
the countersink it leads me to believe someone put their thinking cap on, albiet only for a few minutes...
i'm not looking forward to having this problem recur - so may just ditch the bars.
Back to top
Wed Mar 28, 2007 4:06 am
ive finished making my own crashbars now. theyre at the chromers and their turnaround is pretty crap at the moment. ill post some pics when ive got them back from the chromers.
Back to top
GTS250 GTS300
Wed Mar 28, 2007 9:25 am
I could be mistaken (and hopefully Max will chime in) but I believe that only the GTS has the newly designed Piaggio bars.
Back to top
Wed Mar 28, 2007 9:29 am
How different are the mounting points on the GT vs GTS though? Would it be possible to use the GTS bars on the GT? I saw a GTS with the bars at our last ride and the way it is mounted it doesn't come anywhere near any hoses or air intakes, a much better design. Now I'm a bit concerned about my partner's GT.
Benny
Diavolo Fortunato
Back to top
Sponsor
Wed Mar 28, 2007 4:42 pm
I think they all have redesigned brackets these days.
The GT and GTS bars are not swappable.
Max
Motorsport Scooters
www.scooterwest.com
619-280-1718
Back to top
GTS250 GTS300
Wed Mar 28, 2007 10:07 pm
Good to know.
Back to top
White '09 Super 250 '10 Honda Fury Gone are the VG GT and DW LX
Thu Mar 29, 2007 2:13 pm
Maybe I've just been lucky. I have had the Piaggio bars on mine for several months and (knocking on wood) haven't had any problems with the coolant pipe. I did slightly break the air intake on the tranny like most everyone else but the coolant pipe has been fine.
Before you ride be sure to stretch out those creamy hamstrings.
MV #313
Back to top
ET2, GTS 250ie
Sun Jul 08, 2007 2:44 am
I can confirm that the Faco bars must have redesigned brackets as they come nowhere near the coolant hose.
I'll take some pics when I get some spare time & will post them.
Cheers
Back to top
Vespa GT200L
Wed May 07, 2008 9:27 am
I bought the FACO rear crashbars for my GT200 off ebay. I prefer them to the original Piaggio ones as they don't have the big rails which come up the back and up under the seat. Personal preference. However, they didn't come with any fitting instructions, and just looking around under my scooter, the easy fitting solution didn't immediately present itself.
I was wondering if any of you had printed fitting instructions that came with yours if you bought them direct from a main dealer. If so, could you post them up here? I was wondering also, reading this thread, if there is a way I could identify whether or not my bars have the older brackets that rub the coolant hose, or the newer ones which don't? FACO themselves don't seem to have a support line themselves in the UK, and the main supplier seems to be VE.UK who themselves only seem to interface the general public through their official distributor network, who themselves are disinclined to help me since I didn't buy the bars from them.
I even asked my local Vespa main dealer if they could fit them for me when my GT was last in for a full belt service. When I picked it up afterwards, the scoot was nicely clean and taught, but the bars were still lashed to the rear carrier with a bungee!!
"These are after-market parts.. not official piaggio ones" they said. "We would have had to drill the bodywork to fit them, it would have been a nightmare - so we didn't". Gee thanks. Isn't that precisely the kind of work I'm paying you guys to do since I wouldn't have the kit or the knowledge to do that myself?" Summer is finally here now, and I want the sun to be glinting off my chrome, thankyouverymuch!
Anyway, I am resolved to give it a go myself, but at least I'd like the original instructions if there are any around.
Vespa GT200L, Vespa PX200e Disc, Honda CB1000R
Back to top
Vespa GT200L
Wed May 07, 2008 11:00 am
Scratch that request at least as far as the instructions go. I just discovered this linke.
http://www.scooterwest.com/item_detail/More-Info/340/show_info/yes/
Motorsport.. you guys DO rock! Not only for that but for stocking the whitewalls too. Shame you're not in the UK.
I guess I'll give it a go and see whether the coolant hose rubs. But as the link suggests, a zip-tie could fix it. I see now, that the bars I got didn't come with all the bolts and washers, but I can get some more. I am very happy though, that it appears you DON'T need to drill the bodywork to fit them. Those guys at BMG Lied to me.
Back to top
WHOoligan
07 GTS & 74 Rally
Wed May 07, 2008 11:22 am
motorsports does rock.
I like the stock piaggio bars. no hose problems, held up fine after dropping the scoot at 40mph. I like the way they protect the rear tail light.
MV#4142
First rally: Super Scoot 86
http://www.flickr.com/photos/snapshot05/sets/
Dont be a hater, be a rider
---->No Modern, No Vintage, Just VESPA<----
Back to top
Vespa GT200L
Wed May 07, 2008 11:37 am
Yeah, as I said in my original post, it's a personal preference. I think those bars clutter the otherwise smooth and sexy rear of the vespa. The clincher for me though, was that I think they mount on the same points that are now fully occupied with my Faco backrest/carrier, so unless I wanted to ditch that too, I wouldn't be able to fit the original piaggio part even if I wanted to.
Talking of smooth rear ends, I see with some appreciation in this thread http://www.modernvespa.com/forum/topic24983.html that the new GTS300 has an even cleaner rear end without any kind of carrier bracket. Nice.
Back to top
Daring Plum GT 200, Dragon Red LX 150, Kawi Green KLR 650, Bonneville Black
Fri Feb 06, 2009 12:07 am
Just installed the Cuppini crash bars last week, http://www.scooterworks.com/Cowl_Protecters_Vespa_GT_200__P2197C380.cfm. They looked great, but the front of the right bar seemed too high and tight, so I pushed it down to bend the bracket a bit.
Tonight, pulling into the garage, I spotted a trail of liquid drops on the floor. Sniffed it -- not gas, but a little sticky, Hmmm -- coolant?
Did a Google search: "coolant leak site:modernvespa.com" -- the picture at the top of this thread said it all. I screwed the pooch, but I now know what's wrong and how to fix it -- I hope without having to take the scoot to the dealer. I'm hoping there's enough slack in the hose ...
Thanks MV!
“It seemed the world was divided into good and bad people. The good ones slept better... while the bad ones seemed to enjoy the waking hours much more.” -- Woody Allen
Back to top
Fri Feb 06, 2009 9:21 am
Can you see damage to the hose where the crash bar could have contacted it under suspension compression? If there is no damage, it may be a leaky hose clamp... or it could be oil and not coolant.
I was able to trim ~ 1/4" off and re-use the hose with a hardware store hose clamp.
If you find you need a new hose, PM me as I have one (new in plastic) for the GT200.
-Kip
Thanks MV!
Back to top
Fri Feb 06, 2009 4:55 pm
I jacked the scoot up on the lift and cut off the hose at the annoying, crimp-on hose clamp so I could pull it off. Took the scrap of trimmed hose to Larry's Autoparts and got a new stainless hose clamp and a gallon of pre-diluted coolant. Put the hose back on, less the 3/8 inch I cut off. Looped a cable tie around the hose and tied it back away from the crash bar bracket. Filled the cooling system, which was bone dry.
Then, with a bench vise and a big crescent wrench (and eventually a small sledge hammer ), I "tweaked" the bracket, putting about a half-inch ess-bend into it to widen the clearance between the bracket and the coolant hose and between the cowl and the crash bar. Now, the bar fits and looks better and the bracket is at least an inch clear of the hose. While I was at it, I changed the oil and the oil filter.
Started her up. No leaks. Came up to temperature without a glitch. Topped off the oil. Just another pleasant morning wreching the scooter.
Back to top
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
[ Time: 0.2780s ][ Queries: 25 (0.0768s) ][ Debug on ]
