What's In Your Air Filter
. . 2008 Blue MP3 400. . di Peluria Orso
Sat Feb 06, 2010 4:04 pm
Cleaned my air filter this afternoon. I was surprised for water to pour out when I pulled the cover off. Did ride in some heavy rain yesterday and all the other stuff that gets sucked in it should not be surprising water does too. Below is a picture of what the dirty side of the filter looked like which is typical for me. It is worse when people are mowing their lawns blowing the clippings onto the street.
Picture is before cleaning.
Apply dog logic to life:
"Eat Well, Be Loved, Get Petted, Sleep A Lot, and Dream Of A Leash Free World."
ATG ATT
Back to top
mp3 500 & hoping 4 new guzzi
Sat Feb 06, 2010 4:14 pm
Re: What's In Your Air Filter
typical for agout 2-3k miles. water is what concerns me more. Luthorhuss and I both are lookin to install a aprilla rear hugger to help combat that though.
While U can lead a horse to water but you can't make him drink
http://www.etradebabymail.com/?mId=34288578.3
MV #5270
UPS-SC #8
Back to top
Loretta, '09 MP3 500 Demon Black
Sat Feb 06, 2010 5:08 pm
That's a picture of a filter doing what a filter does, and it seems to do it well for particulates and junk. Water is another story tho.
Question I have is what will you use to clean it and re-oil it? The 'petrol and motor oil' process or do you use something like a K&N filter cleaning kit?
Another somewhat odd looking three-wheeler...
Loretta's Mods!
Back to top
Sat Feb 06, 2010 5:14 pm
I use the K&N cleaner but use a moto-x style filter oil, its really sticky so not dust gets in the injection system.
edit the reason I don't use K&N oil is it is made for a different type filter not a foam style.
MV #5270
UPS-SC #8
Back to top
Sat Feb 06, 2010 5:20 pm
Right, sorry I wasn't clear. I use motor oil after cleaning the filter but used the sodium metasilicate based cleaner from K&N instead of gasoline - with my natgas fired furnace and water heater in the garage I'm a bit reluctant to have gasoline fumes present. The cleaner worked well I think but its not the same as using gas, which probably is indeed better.
Loretta's Mods!
Back to top
Sat Feb 06, 2010 5:37 pm
I use PJs cleaner that works well and then apply PJs foam filter oil It is extremely sticky. Learned to wear latex gloves when applying as it is hard to find anything that will wash it off.
PJs is widely available in motorcyle shops around here.
ATG ATT
Back to top
Sat Feb 06, 2010 6:32 pm
perfect. PJ's foam filter spray is good stuff and I like the foam cleaning products as they won't break down foam air filters like gasoline will over time.
MV #5270
UPS-SC #8
Back to top
GT 125
Mon Feb 08, 2010 9:37 am
your filter has not been installed correctly - you can see a print around the edge of the foam where it was sandwiched between the plastic - the foam should be tucked into the plastic and not become sandwiched - the bit where it has been sandwiched (the print mark) it where the filter halves seal together.
Back to top
GP800, Fuoco, X9 250 Evo, The Hornet and a GTS 250
Mon Feb 08, 2010 10:20 am
It looks absolutely fine to me.
Jim Crowther. Resident curmudgeon.
No more PMs please. I tend not to answer them...
Donkei Skök SC
Back to top
Mon Feb 08, 2010 10:28 am
this is normal. as you can see for the cut outsfor the shape then look at the inner edges of the filter housing, it is designed as to seal that gap .
MV #5270
UPS-SC #8
Back to top
Mon Feb 08, 2010 10:45 am
In the picture the filter is flipped over compared to the cover it is sitting on. The imprint is from the raised portion inside the screw pattern and designed to seal against the filter. It was inside the outside portion of the filter cover and is contoured to miss the screws.
ATG ATT
Back to top
Piaggio Mp3 LT 250
Mon Feb 08, 2010 1:04 pm
+1
Back to top
MP3 500
Mon Feb 08, 2010 4:01 pm
If it's not sandwiched between the two halves air/dirt will go around the filter. It must be sandwiched between the halves to work properly. If yours is not installed properly you need to get it fixed ASAP.
Back to top
Mp3 250 Lt
Tue Feb 09, 2010 12:11 am
Goodmorning (or afternoon )
There is a tiny round compartment in the rear part of the filter box. It can be easily seen. Does anybody know what is it?
I guess it's just a sort of overflow??
Any ideas?
Back to top
2009 MP3 400
Tue Feb 09, 2010 7:13 am
We use MAXIMA filter cleaner and filter oil, both work very well and easy to use.
+ one on the filter installation looking proper, looks fine to me from the imprints.
Back to top
MP3 500
Tue Feb 09, 2010 9:05 am
You really should use filter oil. It is much tackier than motor oil & catches smaller particles of dirt.
Back to top
Red MP3 500 RUBY DRAGON
Tue Feb 09, 2010 7:29 pm
Just bought the Maxima cleaner and oil today. "Air Filter Cleaner" spray, and "FAB 1" spray respectively. Around $18.00 with tax total.
Mods: GIVI windshield and E52 topcase & ZUMO 550 w/Touratech mount & DL650 handguards & JCosta Var., Crank Case Breather Relocate, Steibel Horn, LED Brake/Turn signal lights.
Yet to be: HIDs & Seat & Laminar Lip, Pillion Pegs.
Back to top
Tue Feb 09, 2010 8:08 pm
Yeah, probably a ton of things I 'should' do, but I don't. For now just kind of following the O&M manual and using oil, but without gasoline. Not hyper-concerned about it, especially with the constant damp and cool weather.
Loretta's Mods!
Back to top
Tue Feb 09, 2010 8:52 pm
What oil you should use on air filters (and how often to clean/change any filters) really depends on where you ride and the prevailing atmospheric conditions.
There's not one rule for all, but the 'book' intervals are very conservative. If doing your own maintenance, consider stretching these times/distances - use your own judgement.
Oh, and changing engine oil every 2000 miles and often in less than two months as one contributer does here is simply a waste of money.
Donkei Skök SC
Back to top
2009 Piaggio MP3 400ie
Tue Feb 09, 2010 9:11 pm
Min / Max times between oil changes
jimc wrote:
...changing engine oil every 2000 miles and often in less than two months as one contributer does here is simply a waste of money.
Jim,
Do you have any developed opinions with regards to minimum / maximum time one should allow for oil changes?
EXAMPLE:
At a minimum every 6,000 miles / at a maximum go no longer than 10,000 miles between every oil change, etc., etc.
OR.... conservatively once every twelve months / liberally allow no longer than 18 months between oil changes regardless of usage...etc., etc.
chris
Back to top
Tue Feb 09, 2010 9:38 pm
Zero miles? Some would say every year - but that is an obvious nonsense. How long has the oil been in the container...
It depends. On monthly/yearly mileage and the conditions. I personally reckon the Piaggio 6,000 mile interval is on the edge, it works for users who keep an eye on things, and not so good for numpties who look at fuck nothing between these intervals.
But it is the warranty service interval for FI engined scooters, so Piaggio are evidently happy to live with it.
If I just used my bike for commuting, I'd be far more concerned about battery issues than oil ones, I have to say. Horses and courses...
Donkei Skök SC
Back to top
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
[ Time: 0.2141s ][ Queries: 25 (0.0341s) ][ Debug on ]
